December 2, 2020 at 9:37 pm
The KB4579311 not causing issues. I found that the win 10 version should be not later than 19041.450. It easy to check by launch winver command in searchbox. nHere the list of problematic KBs:nKB4576478nKB4571756nSo, you should keep next KBs configuration in Microsoft Windows update:nKB4580419nKB4566782nKB4570334nKB4586781nKB4586864nSome KBs hides after another KBs. You should remove as much as possible KBs and hide the problematic KBs by wushowhide.diagcab, but more stable is to downgrade win 10 to 19041.450 build and do not update.nnAnto
