Keyur Kanade
In mechanical you can see question mark at the geometry in structure tree. This means geometry is not imported in mechanical. nCan you please create a simple box and try to import in mesh? If it imports well then there is no installation issue. nHow many bodies you have in DM? There are limitations with academic license on no. of faces. nnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
