December 3, 2020 at 6:28 am
Thank you for the response Sir. I have defined the material properties on Engineering data, built the Geometry, am on the mechanical APDL interface to model it, however am confused as to what to do next, I have a double skin hollow column, I want the outer skin to be FRP and inner skin to be Steel while the Concrete is between the FRP and Steel, the middle is left as a hollow. Please how do I go about this Sir?n
