abi151994
Hi Kumbhar, Yes you are right. The problem was due to my geometry. Previously I had shared topology between the different bodies in the same part. Hence when I select anchor faces, Mechanical was not able to detect which body I am referring to, as the face is shared between two bodies. After I removed the shared topology, it is working fine.n
