If you'd just labelled the surface between the two fluid zones as a wall you'd have been able to display it and give it a thickness in the solver (it'd come through as wall and wall:shadow). As the geometry is zero thickness (we cheat and can give it a thickness for heat transfer) you can report numerical values but images are more limited: it's a 2d surface. n
