December 3, 2020 at 12:42 pm
nYou can use APDL command snippet under the Anaysis Setting. Select the elements that you want and change their material properties.nYou can use ESEL command to select elements and create component of it. Else if you have defined Named Selection in Mechanical, you can use it as component name in command snippet.nYou can place the command snippet under Analysis setting. Then you have add first few commands as belownFINISHn/PREP7nAt the end of snippet, you have add commands to go back to solution entrynFINISHn/SOLU.
