nTarget elements are created on rigid bodies to enable Contact to be computed.nRigid bodies will only have rigid body motion. If the part is fixed, then there will be zero deformation.nAll this is normal.n
New Post - Reply To: why meshing generated for Rigid body in Static Analysis which is target body in CONTACTS ?
