December 3, 2020 at 12:54 pm
You can connect 'solution' cell of thermal analysis to the 'setup' cell of structural analysis and solve the structural analysis. You will get the stresses due to thermal analysis. Furhter, you can apply other loads in second load step in structural analysis.nYou can also export the stresses X,Y,Z and XY,YZ, ZX component. You need to plot these results in Mechanical and then right click on them to export in csv format. The you can use 'External Data' system to import these csv file and connect the 'External Data' to 'Setup' cell of new model.n
