Vassilis
thanks a lot for taking the time!nI will give it a try and will come back.nDo you happen to know if there is any build-in functionality, or respective commands that match points in space with elements that have been generated through meshing?nOtherwise, the elements that should be selected should be calculated in a script outside ANSYS.nnThanks again!n
