Govindan Nagappan
Array nAre you using any ACT extensions. Check and see if this popup is generated by ACT extension. From project page, go to Extensions -> View log file to see if there are any errors printednTry this and see if it helps:nCLose all Ansys and WB applicationsnOpen a directory/folder and type this address %appdata%\Ansys\ and press enternRename the folder V192 to V192_old and start WB againnWB should start with default settings. See if this resolves the issue. Any ACT extensions will have to be reinstalled after thisn
