Rahul Kumbhar
You can use 'External Model' in Workbench to import .cdb file. Then Connect the External Model to Static Structural Analyis. From Static Structural analysis you can export Geometry in pmdb file. Or solve for dummy load and export deformation in stl format. The pmdb file can be read in Spaceclaim and convert into STL.n
