TingWangUNO
By resolving the velocity gradients you mean to get lower value of y+ value? right now it it ~220.nI believe the velocity gradients are resolved as the case S-2 gives good results. However, is it possible that the Case S-5, which has more heat flux at the wall and hence more condensation, is affected by the temperature in the domain and not the velocity gradients?nThank you.n
