I suspect you have many surfaces and the meshing tool hasn't split these to avoid getting an excessive number of labels. Try and follow the workflow through and see what you get in Fluent solver. As a comment, if you use Named Selections (Groups) in SpaceClaim you can label surfaces you need as boundary conditions there, makes it easier when you get to the solver. nDId you want Japanese script? If not have a look in the installation sections as this was a common question before the summer. n
