Keyur Kanade
For layering technique, please change split factor and collapse factor to avoid negative cells. Also make sure that you are using small time step. nFor UDF, we will not be able to debug it. You will need to cross check. Please check where did you hook UDF. nPlease go through help manual for more detailsĀ nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
