Keyur Kanade
Please check join/intersect command. Please see help manual for the same. nWith join/intersect you can connect different faces. Once you get connected geometry, you can rename boundaries and change type in Fluent. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
