ydai
Hello Larissa, n Can you please clarify what you mean by water loss? If the goal is to predict the flow rate of the fluid through the screw extruder , you can try to use force type of bc with force free condition fn=fs=0 if both inlet and outlet are exposed to the atmosphere, I am assuming the flow is one that the twin screw extruder is half filled with the liquid fluid, related with the question you asked last time.n Thanksn Yin n
