December 28, 2020 at 5:57 pm
#1 n#2 I can't understand exactly what he meaning by loading plate did he mean the force applied in the beam arm or the axial force acting on the column if you see my model I have applied a remote displacement to simulate the axial fore of the column and I have sliced the face of the beam to insert a force on beam arm so did I need to do more.nAnother question of how could I draw the moment rotation curve in ansys the research explained some rules to draw the curve n
n
but I don't know how to evaluate these resultsn1- (P) n2-(Δep) when should I select probe deformation geometry to calculate endplate deformationn3-(Δcft) when should I select probe deformation geometry to calculate column tension deformationn4-(Δcfc) when should I select probe deformation geometry to calculate column compression deformationnand I have attached my model if anything I have to do please tell me.nthank you for your response.nbest regards; nAymannn
