nInsert a Mesh Edit and add a Mesh Node Group to find all the coincident nodes that are unconnected. That will fix your excessive deformation.n
Note that you only constrained 5 DOF with the Simple Support and the Displacement. You left rotation about those two points free. Weak Springs allowed the solution to converge. You should pick another point to constrain rotation about the axis formed by those two points.nn
