I have a problem using ANSYS LS-DYNA. I have installed the ANSYS software through CMC with the license: Ansys Campus Solutions (Research). Later, since I needed to work with LS-DYNA, I found that the student version has this for free. I have installed the Ansys 2020R2 LS-DYNA Student. However, I cannot open LS-DYNA. Image1 shows the options I see through the start menu.https://us.v-cdn.net/6032193/uploads/H9F7OMLLRHQQ/image1.pngWhen I click on LS-DYNA PowerShell from the Start menu, the LS-DYNA Powershell window pops up. (Image2) https://us.v-cdn.net/6032193/uploads/NB97UYA81U5T/image2-png.pngFrom this window, I can open LS-Prepost just by typing lspp. However, to work with LS-DYNA, when I type lsdyna in the command prompt, it gives the following error (Image3), and I am not sure how to fix it. https://us.v-cdn.net/6032193/uploads/AYORAGNGBLJ4/image3-png.pngYour help is truly appreciated!https://forum.ansys.com/discussion/23159/how-to-open-ls-dyna
Thank you.nKarthikn
