kkeikhos
Hi,the Virtual force is correct. it might require a bit more care in meshing but the results are the same. That being said, if you are applying single frequency excitation, you can use EddyCurrent Solver. In EddyCurrent Solver you have an option for Both Virtual and Lorentz Forces (you can see there that both forces in fine enough mesh setting and number of passes will converge into same results).Hope that helps,n
