Konstantine Kourbatski
1) Your plot is counter-intuitive. For gas, you are inducing gas out of the domain through the inlet, yet pressure at the inlet is higher than at the outlet. My expectation is for the flow to move from the region of high pressure to low pressure, and not the other way around. Are your inlets (or phases) inverted by chance?n2) Is your simulation axisymmetric? You use r-z coordinate axis, but in Fluent the axis is always x-axis in axisymmetric problems. Just checking if this is simply your convention of naming the axis.n
