kkeikhos
Hi,Best way to work with workbench is to start from workbench. that means in workBench you can insert a Maxwell component and after opening the Maxwell component from WorkBench you can add more design within the Maxwell. now when you close the Maxwell it will update the workbench project as well. nbtw, why are you trying to import the Maxwell project into workbench?.n
