nInsert a Contact Tool under the Connections folder then right click to Generate Initial Contact Results, then look at this table.nThe last row in white shows a penetration of 0.67558 mm on a Frictional contact. If you go to that contact, you can see the geometry.nThe stress at the top of the part is caused by the huge amount of interference in the geometry being resolved by the contact algorithm.n
