Keyur Kanade
This is Ansys Meshing. nIn this case, you will need more splitting at the geometry level so that each face is mapable. nFor inflation, you will need to use edge biasing to get inflation effect with hex elements. nBetter you can use tri+ prism. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
