First, that's not an error, it's trying to start at that point. Are you currently connected to a VPN, as that could cause problems. Have you looked to see if there is an environment variable ANSYSLI_ELASTIC set on the machine, and if so removed it? Please try launching Fluent with these options in the Parallel Settings tab.n
n
