December 31, 2020 at 1:20 am
@peteroznewman,nWhen I run the model by giving EQ load as displacements, following errors pop ups. Any reason You can mention?nI have used lagrangian for water tank and eulerian for water. I fixxed the bottom face and gave displacements. Errors pops up. Then I removed the fixed bottom face and gave displacements. Same errors pops up. Can you mention how to fix it? Thanks for the help. model attached.n
n
