Navya C
Hi,nWhen you create the sheets you will get two sheets for each coil.nYou need to give current excitation to only one sheet and deleter the other sheet for the same coil.nHave done this ? or assigned the current excitation for both sheets which is not correct.nnRegardsnNavyan
