BenjaminStarling
nIf you just want the top layer of nodes, create the face named selection in Mechanical as I mentioned previously. Remove the esln command that I suggested above. Also remove the esln command you have after CSYS,0, and use the SF command instead of the SFE command to apply your heat flux.n
