ChaitanyaDS
Hi,When you create the sheets you will get two sheets for each coil.You need to give current excitation to only one sheet and deleter the other sheet for the same coil.Have done this ? or assigned the current excitation for both sheets which is not correct.RegardsNavyahttps://forum.ansys.com/discussion/comment/101538#Comment_101538
Yes, I did change that after you have mentioned, but the error remains the same for the rest of the coils.n
