mahesh2444
Hi ArraynI am performing reflectarray simulations using Domain solver.and Horn are separated by creating FE-BI boxes surrounding each of them. For clear picture of my simulation setup see this
target=blank>
Youtube VideonVideo summarynHFSS using Hybrid technique to implemented here. The entire simulation domain is divided into two FEBI region and we can avoid mesh between horn antenna and reflectarray. Hence reducing simulation time and memory consumption.nWhen I tried to simulate the above described setup, only first machine in the list is getting used for adaptive meshing and second machine remains idle. Eventually, this causes Out of memory issue leading to abrupt termination of simulation. nHow could I make my two machines to be used for adaptive meshing just happened with the case of direct solver ? Please help me.nThanks nMaheshn
