January 3, 2021 at 9:08 am
I believe both ways should be doable.nIf you are using it interactively I would do the later, i.e. extension with a button, where you can take user inputs for things like folder path etc.nBut if you are doing this in batch you should be able to use sendcommand to send this using technique discussed in Run Mechanical Macro from Workbench ? Ansys Learning Forum but please note that you might not be able to run it in total batch mode, image export mode requires display afaik.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
