MiguelGuerra
Sorry, I have reread the UDF Fluent Manual and I have noticed that in the  DEFINE CG MOTION description it says:Note that UDFs that are defined using DEFINE CG MOTION can only be executed as compiled UDFs. I did not compiled the code, I used the Interpreted function, may this be the error why I get the assuming no motion problem?nThanks for you attention.n
