January 4, 2021 at 5:07 am
What are you trying to solve? What are your boundary conditions? nThe message is for pressure couple solver. It is trying to stabilize the solution by using some relaxation factors. If not done, nPlease make sure that you are using correct boundary conditions and numerical scheme. Also make sure that you have sufficient mesh density. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
