Keyur Kanade
Are your boundary names same?nIs your mesh same? nI assume you are changing only values of boundary conditions like inlet velocity etc. nIn this case, you can read old data file and resume calculations. nYou can also write and read interpolated data. nThe best way is to use parameters in WB. Then you have option for using previous file as initial file for next design point. Please search this forum for the same. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
