Navya C
Hi,nAre you reducing or increasing the region size?nAs long as the region is sufficient enough to cover the whole field distribution you should get the same result for anything Region size above that region size.nBut if you are reducing the computational region such that it is not fully enclosing the whole magnetic field you will get a difference in results.nYou can plot the fields and check if all the dominant filed lines are enclosed in the region to figure this out.nnRegardsnNavyan
