nIn the details window, you changed the Normal Stiffness Factor to 0.01 which is used to multiply the stiffness ANSYS calculated to keep the two parts from penetrating. Change that back to 1 and you will get 100 times less penetration. If that is still too much, you can use a Normal Stiffness Factor of 10 or more to get even less penetration.nn
