HuiLiu
From the model setup, you specified a displacement 26.78 which ramps down to zero at end of simulation. After the contact is activated, the spring on the right should stretch while that displacement ramp down to zero, and the displacement result you showed appears to agree with that. Could you clarify further on the problem? Which spring is supposed to go back to its original position, the one on the left or right?n
