January 4, 2021 at 6:37 pm
ArraynI misunderstood your meaning of a segment. A segment is the name of the part you are testing. Eight segments are assembled to make a complete stator, but you are not testing the complete stator, you are testing a segment part on its own.nThe brackets on each corner that control X and Y should be added to the simulation as they will interact with the segment to constrain motion in those directions.nThe bracket design is important. If you hold four corners of a part fixed in X and Y, that is 8 constraints, which is an overconstraint since there are only 6 DOF for a rigid body and at least one DOF, Z, you want to be free to find equilibrium with the springs.nPlease provide details on the corner brackets.n
