Navya C
@johnfides nI tried doing a similar instantaneous force setup using the eddy current solver. I did not find any change in the force magnitude with an increase in the region size.nCan you please confirm if you got the same result as shown in the tutorial if you follow the tutorial?nIf it is not, please share the comparison screenshots of the tutorial with your result.nAlso, confirm which version of AEDT are you using?.RegardsnNavyan
