January 5, 2021 at 2:06 pm
But that doesn't happen if those were not the same hole, but instead two different holes. I mean another body right after the greenish-gray one, also having a hole in there. And the line body is extended and its vertex is also fixedly joined to that additional hole. Then each of the hole will take a portion of the forces and moments. Is it correct, ? [Assume that the extra body after the greenish-gray one, also have the fixed support as like the greenish-gray body].n
