mohammedlaminemekhalfia
I thought that it will better to explain with picture.nThis picture is token from one Ansys courses and I am using it to explain.nI have the same blade, the Nozzle will be placed against several points . the objective is to observe displacement caused by Nozzle output air pressure.nthe 1st step will be the static one where the blade doesn't rotate, then I will add rotation.nofcourse I will use different architecture of Nozzle in order to fabricate the best that suits me for a real experience latern
