January 5, 2021 at 8:39 pm
Hi vaibhavtaranekar, I found the same issue as you. It seems like the damage outputs do not work in workbench when there is more than 1 step. Could be we have the commands wrong. A workaround that I used was instead of using steps, just use time. So I created a model that goes to 2s, instead of 1s, and then apply the loading conditions differently at 1s and 2s which basically comes out to the same thing as 2 steps. This method then works, and you can output the damage models at different times. I posted a brand new video on this here!:nn
