Rameez_ul_Haq
Array, Use a Sizing Mesh Control to force 2 beam elements onto one line body.'', you mean to say that ATLEAST two elements right?nto model this, you would create a line body across each gap.'', you mean to say that a separate line body should be used for each gap, right? Or a single line body passing through all the holes also mean the same thing (with vertices onto the line body, each of it connected to each of the hole).nLet me check out the links that you have shared. I am sure they will be helpful. Thank you n
