,your opinion on this will be so much appreciated.nPlus, consider the figure below. Each plate is 2 mm thick.nWhy does the geometric gap keep on changing with the change in the pinball radius? What does geometric gap imply? nRight now, the SHELL THICKNESS EFFECT is turned to NO, how would you expect the sticking region to change if it is changed to YES?n
