Navya C
Hi, ncan you first confirm whether you are getting the same result as the tutorial with a single conductor?nAnd is the result varying with region increase in that case?nJust want to make sure what you and I got is the same. nAs I said, I did not face this issue with region change for a single conductor.nI do not have Maxwell 15 installed, that very old version.nYou can also try installing a latest version of AEDT (2020 R2)n
