Surya Deb
Hello, nPlease make sure that the initial mesh is fine enough. Generally CLSVOF needs finer mesh as it is a continuously varying function. nAlso CLSVOF is generally required for calculating very accurate surface tension forces. As the surface tension is directly dependent on curvature calculation which clsvof can predict accurately.nDo you have dominant surface tension in your model?nRegards,nSuryan
