attiq
I tried changing the version of MS Visual Studio and Tried running or opening fluent through RUN PROMPT. But every time I open I had to do it through VS Run Prompt. The problem is partially solved. Even through VS run prompt, sometimes fluent fails to load UDF. But sometimes it works fine.nExperts advice is still needed.nThank You.n
