nHere is a fixed support.nHere is a small body connected to the large body below only by Frictional Contact on a plane. There is no force pushing the two parts together, so there is no friction force and the small body is unconstrained. This problem occurs at many points in the assembly.nIf you convert all the Frictional and Rough contact to Bonded, it will solve. n
