nYes, put a 3 in the Newton-Raphson Residuals field. That will cause three plots to be saved under the Solution Information folder. nWhen the solution fails to converge, you look at those three plots. The max value shows where the solver is having difficulty converging on a force equilibrium. The corrective action is usually to make smaller and better quality elements around that location.n
