January 7, 2021 at 6:44 am
Is this error for this particular file or all files? It may happen that cdat file is corrupt. nCan you please do simple test case?nWrite .cas and .dat file from Fluent for a simple case. Then try to read in CFD-Post. nIf simple case also gives problem then there may be some installation issue. Please check if you can reinstall latest version available. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
